Knauf drywall adhesive it’s moisture resistant plasterboard
Jfix
Hello
am giving dot and dab a go, but have just read on the Knauf guide NOT to use Knauf adhesive with moisture resistant boards? what do you use then?? Or can you Pva the back and still use it? Was supposed to be doing it today in prep for tiling, any advice much appreciated.
Hello
Just crack on
Hello
put the moisture board in the skip and go and purchase some Hardie cement board to receive tiles.
Hello
Contacted knauf technical, they dont recommend dot and dab with moisture board because of ‘high silica content’, it’s only to be used with batten! Got smaller cement boards instead, plus they fitted in the lift
