Knauff Pro roll light
Hi all,
I did some plastering of my kitchen walls to hide tape that my plasterer had left connecting the ceiling to the wall, i used was easifill followed by knauff pro roll light, i also used it around window areas. I was doing a mist coat (60 % paint to 40 % water) yesterday and it seemed like the plaster was turning into mud again. After some research it looks like it’s not a good idea to plaster using the stuff on high moisture environments, is there a way to remedy this ? Or is it going to be an issue once painted over in the future
Hi all,
Yes!
The problem is the paint to water ratio!
It should’ve been 40% paint 60% water
You may have to remove and redo I’m afraid!
