If you are cracking over meshed basecoat with FT next time try adding a touch more water to your mix and giving it a double mix with a rest in between, alternatively with K1 add a bit less. FT is cement heavy and not enough water can make it a bit strong, and K1 is not as cement heavy so too much water can make it too weak.
