Can you use the Ocr on 7n blocks?Has anyone used this as an OCR...2 passes wet on wet?
Whats it like is it similar to Weber OCR? or is it better 2 coats?
YesCan you use the Ocr on 7n blocks?
So if you did it in two passes could you prime and apply 1.5 m silicone?
Yes I've used it a fair bit and no it's a 2 coat system render
It has that k rend aggregate feel to it which I'm not keen on
Cheap though
YesMight as well use CPI then even cheaper...can you power float it?
The problem with CPI is that there's a delivery costI've found CPI dearer than OCR.
That's even with collection. I've got a couple of merchants fairly close and OCR is cheaper.The problem with CPI is that there's a delivery cost
Go direct to minister and pay nothing
Bobby out of interest why would you scratch and top with krend or cpi before thin coat when you could do it in 1 coat with 10mm beads dabbed on Weber OCR?
No need for scratch coat if receiving texture finishBobby out of interest why would you scratch and top with krend or cpi before thin coat when you could do it in 1 coat with 10mm beads dabbed on Weber OCR?
I see...do you think the same would go for cullamix Tyrolean...got a job coming up and thought I'd give K Rend a try.
