smudgez1000
I'm at that stage of thinking monkey poo is the way to go... And quoting myself! WtfWhat's It like over painted render? If it sticks and I can towel it on I'm there!!
I'm just gonna get confused with which way to go!
It doesnt like me very much... And i can understand that
OK mate.send me a screenshot and I will forward that to the tech team we are messing about with settings to get video uploads to work so that may be an issue
do you pin it aswell Bobby or just straight over with parinterI wouldn't be putting anything over painted apart from a thin coat render system
Parinter/mesh and 1.5 all day long
nice one palI've never pinned it tbh mate
I'll do a pull test with mesh then crack on
Done a few thousand m2 with it last year
Thanks.... Yeah I'm thinking I might just have a go at krend. What could possibly go wrong?!!In a nutshell, lots of stuff that will stick, choose your poison.
No one will guarantee that your paint will not peel off.
scratch pad you want mate not a devil float that only has two nails at the topThanks.... Yeah I'm thinking I might just have a go at krend. What could possibly go wrong?!!
Hp12, mesh and top coat. I fancy trying it, so as per the first post... Any tips are more than welcome! It'll be about 3 weeks from now I recon, gotta get an I beam and devil float
Could record it all for us ..would be good to see how it all turns out.Thanks.... Yeah I'm thinking I might just have a go at krend. What could possibly go wrong?!!
If your going to use hp12 you would be better off using tc15 bucket coat for the finish,less weight and less chance of cracking.Thats just my opinion tho.Thanks.... Yeah I'm thinking I might just have a go at krend. What could possibly go wrong?!!
Everything can go wrong!!!Thanks.... Yeah I'm thinking I might just have a go at krend. What could possibly go wrong?!!
Mate if he doesn't even know what tools he needs he f**k*d!!!scratch pad you want mate not a devil float that only has two nails at the top
Can you get hp12 rubbed up nice ready for thin coats or is there a more suitable k rend product mate used ft a few times with hp12 but I've done no thin coatIf your going to use hp12 you would be better off using tc15 bucket coat for the finish,less weight and less chance of cracking.Thats just my opinion tho.
Yes mate its nice gear to use sponges up nice or you can spat it flat and leave it. Don't have to be like glass if your using a 1.5mm or larger grain topcoat. If using 1mm it does have to be mint.Can you get hp12 rubbed up nice ready for thin coats or is there a more suitable k rend product mate used ft a few times with hp12 but I've done no thin coat
Cheers for that mate a was under the impression you had to spat then sponge before top coat. As a say used it on ft and thought it was spot on for a base but a found it a bit gluey and splitting if a messed on too much with it. Probably me trying to get it bang on too soonYes mate its nice gear to use sponges up nice or you can spat it flat and leave it. Don't have to be like glass if your using a 1.5mm or larger grain topcoat. If using 1mm it does have to be mint.
Without seeing the job I would probably make good the beads and then just use a 1.5mm texture coat straight over the paint if the walls are relatively decent.
Would you bother with acrylic primer first ? Or straight into painted walls? ThanksNice to see someone talking sense instead of doom for once. HP12 is great gear, used it on dozens of houses over all sorts and never had a failure.
