You'd have it boarded + skimmed for dinner!! [emoji4]nice day for someone![]()
You'd have it boarded + skimmed for dinner!!![]()
Use Knauf mp finish last week put a big area on and the f**k*r set in 50 mins was running round like a headless chicken. Nightmare used to love the stuffRolling gauge using Knauf,one mixing two putting on ,then one dropping back with Eze spat ,and the one mixing does edges,would nt attempt it with thistle,
Knauf far better for big ares
3 buckets for first coat and 1 to lay down your putting in on too thick mateA good easy for a good spread???? Did I say that
If your mixing your self then yes it will be a good old hit of skim
3 buckets then maybe 1 more for second coat.
A nice sat morning job
Well how many meters do you get out of a bag?3 buckets for first coat and 1 to lay down your putting in on too thick mate
Each to there owni put 2 1mm coats on i get about 14 m2 out of a bag
Cuts the set time down as well!Best way to do it and no water trowelling up
U get alot of that black grit tho gibbo? Hate putting it on thin because of thatWell it works for me 34 years long
Did they use multi 34 years agoWell it works for me 34 years long
f**k knows was rustling around in my fathers ball sack 34 years ago..think it was carlite finish mayb or mayb was multi..flynny will know he's about 60 I thinkDid they use multi 34 years ago
I finish when its wet no polishing waste of time 2hour sets
I can't see how you could get over the skim and dodgy boarding with 2mmBest way to do it and no water trowelling up
f**k knows was rustling around in my fathers ball sack 34 years ago..think it was carlite finish mayb or mayb was multi..flynny will know he's about 60 I think![]()
I slap it on 10mm thick then get my sand blaster out and knock it Down to 2mm..comes up lovely jubbly it does..any1 got any work for me?
Make It wed and we can both sign on 2gether..mite aswell kill 2 birds with 1 stone palI'll pick you up Tuesday .
Scroungers lolMake It wed and we can both sign on 2gether..mite aswell kill 2 birds with 1 stone pal
