Same as you mate.always for the dash mix cos it bulks it up nicely and holds the stones better I findProb been discussed before but can’t find the info. Was thinking of going back to the old way I used to render. 6:1:1 Sand:cement:lime. Anyone else still use lime and for what reason
Dubing out on stone work and I use just a touch when dashingProb been discussed before but can’t find the info. Was thinking of going back to the old way I used to render. 6:1:1 Sand:cement:lime. Anyone else still use lime and for what reason
Why. Even if the wall is going to be paintedAlways but we use fine silver sand
Fine silver just doesn't bind without limeWhy. Even if the wall is going to be painted
I've always used fine soft washed sand for my patterning and paneling.Fine silver just doesn't bind without lime
I thought the lime helped with absorbing stresses through thermal expansion and moisture5 sharp 1 cement 0.5 lime each to their own
You wouldn't want to rub up some of the sharp sand I've screeded with!5 sharp 1 cement 0.5 lime each to their own
Nice sharp in Bedfordshire , never soft in top coat , no point in making it easy for yourselfYou wouldn't want to rub up some of the sharp sand I've screeded with!
I use nhl 3.5 , never had any problems , although its a pretty stable climate here in Bedford perhapsNot to be technical but hydrated lime is used as a plasticser, and also to increase suction in subsequent coats, ie tryolenne, pebble dashing, or wet dash. Use of hydrated lime is fought with problems because of shrinkage chemical plasticser much easier to matain mixing ratio too
how do you leave a nap finishUsed it for this mix. Brings more fat up for napping. Finish we do here in Ireland.
View attachment 25254View attachment 25255View attachment 25256
Great name!Not to be technical but hydrated lime is used as a plasticser, and also to increase suction in subsequent coats, ie tryolenne, pebble dashing, or wet dash. Use of hydrated lime is fought with problems because of shrinkage chemical plasticser much easier to matain mixing ratio too
Great name!
pipe down you’re married now
It is indeedGreat name!
How do yo
Exactly @JessThePlasterer haven’t you got some socks to sew up somewhere? Lol.pipe down you’re married now
Di just offered yesterday to see the hole up in my pajamas.... so no thanks I’m good! Got my s**t all sorted over here!Exactly @JessThePlasterer haven’t you got some socks to sew up somewhere? Lol.
Glad to hear you’ve got him well trained.... Oh by the way Please remind him to wear marigolds when washing up, you don’t want his hands getting all ruff and horrible?? XDi just offered yesterday to see the hole up in my pajamas.... so no thanks I’m good! Got my s**t all sorted over here!
See up the hole!Di just offered yesterday to see the hole up in my pajamas.... so no thanks I’m good! Got my s**t all sorted over here!
Good cheersSponge float over it. Throw drop water, rub it lightly and nap. You have to be very carefurl because if you nap to hard, it shows all over the wall. Done correctly it looks good. TBH, I've always rubbed up with sponge to finish after floating but starting to like napping instead. Will get close up pics next time for ya. Its like a sort of light artex finish with S&C.
So still finish with a sponge and floatSponge float over it. Throw drop water, rub it lightly and nap. You have to be very carefurl because if you nap to hard, it shows all over the wall. Done correctly it looks good. TBH, I've always rubbed up with sponge to finish after floating but starting to like napping instead. Will get close up pics next time for ya. Its like a sort of light artex finish with S&C.
Sounds horrific!Still throw the float over it then grab a sponge float, throw bit water on it like as ya do when skimming, lighting rub it with the sponge float and lightly pull it so it sucks the fat off and leaves a raised finish something like artex.
