Lime plaster
eastplastering
Hello everyone.
Am making plaster by mixing non hydraulic lime powder with sand. Could anyone clarify the difference between slaked and un slaked lime, and is one better to use than the other. Also, maybe a silly question, can I sweep up dried mix , and re mix it, or has the carbonation process started, can the carbonation process be reversed by adding water...?
Many thanks,
Rob
The answers to these are on nearly every lime plaster sellers website. I suggest you do some proper reading and research. If you ask silly questions on here you will get silly answers.
