Im looking for an alternative to DG27. Its really expensive and I need a primer. Thinking I could mix it up myself if I got the ingredients..... Anyone know of any cheaper alternatives or how to make it?
Don’t be a cheapskate use the right gear for the right job! If you’re in the trade allow this within price! If you’re a customer stop been a dick it is what it is!
Question about blue grit ... have already preped block wall with blue grit ready to skim. But will now use lime to match in with other walls. Will the lime render be OK on the blue grit? Any other prep recommended? I will be using Cornerstone Dry Mix CLD30 NHL 2 (9mm) with 2 coats of lime putty to finish (2 x 1.5mm). Blue grit specifies 12mm max total plaster thickness. I'm a sparky renovating my own property - so go easy on me!
