Wont be nxt day pug will be a few days later..60-70mm depth in some places so building the fcker out..think it wil need a pva if skimming Thursday? Some of s**t has been on since Monday..ive used renovating b4 just never this finishFirst time I used the backing plaster I soaked the walls and it hung like feck so I just give the walls a light mist to kill any dust. Nice gear to use imo. Skim as normal with the finish the next day.
Ye pal..nitemare some of depth is 70mm thick and numpty foreman Is asking where all gear is going..told him to chisel into it and see how thick its going on..will be walking off 2mz if contracts manager dsnt give wat we want £20 a bag we are asking or we are off..What background you laying on mate? Hacked off bear brick?
Even if some has been on since Monday pal? Ive heard it takes a age to go offdon't wet down mate straight on with it you will need suction believe me that shhit hangs around for ages so you will get loads on don't try an get on it too early either it's not like multi
tell him to get fukked the nobThis is kind of walls we are dealing with and textbook foreman cums in and asks y we r using so much gear..said look mate If you want a proper job this is the amount of gear ur guna use said his day rate lads dont use as much I said ye but this is rite...said where u think we are putting all gear in our sandwiches
Had to build the f**k*r out in stages to get it to correct depthThe longer you leave the backing the longer the skim takes to set we found out I didn't think you could go to that depth with it? Anyway tip for skim chuck a couple handfuls of board or multi in with finish sets up quicker but don't put too much in as it will turn pink [emoji106]
With sounds of this mite bang all downstairs on Thursday if still there that isWe had to use the lime lite slurry coat first and put a 10mm scratch coat on leave it a day or so and another 10mm topper scratched to receive the skim, compel of days later when it's ready knock the skim up leave it 5 mins remix and was spot on we could spread a lot as in a complete down stairs before it started pulling two coat it and use as little water as possible [emoji106]
It's worth a punt mate, if you get caught short there's always sandpaper lolWith sounds of this mite bang all downstairs on Thursday if still there that is
Tbh mate cudnt care less wat spec says on owt if isn't my own job..foreman points to gear and says that goes on there bye bye..aslong as its rite and I get paid Il save spec sheet for wiping my arse if run out of paper..a spec sheet says alot of things that r pointlessI was told by contractor the spec from limelight at those depths is 25 mm pass the eml fixed with mushroom fixings then another and repeat till desired depth is reached passed on the job after that
Was just saying like... Still love me kitchy?! Did the manager fork out what you wanted thenTbh mate cudnt care less wat spec says on owt if isn't my own job..foreman points to gear and says that goes on there bye bye..aslong as its rite and I get paid Il save spec sheet for wiping my arse if run out of paper..a spec sheet says alot of things that r pointless
Wil always luv u builderboi..ye he's giving us wat we wanted but last day 2day as plastering contractor we are doing job for isn't vat registered and we are so he said he cant claim vat so we r not doing it..fair to say I'm not that bothered..typical as price just been agreed came in this morning and said dont throw any bags away so we can count them at end of day..wheres the trust manWas just saying like... Still love me kitchy?! Did the manager fork out what you wanted then
