Lines in finishing trowel
Wet and dry sponge pads work well
Not too aggressive on the fine edges.
Nice fine grit (higher number)
Nela Black are the best I've used mate. Tried a few ! (y)
Not really had a bad tool from Nela
Original chrome trowels were good although a bit stiff in the beginning, then flexes and medi's both good
Their black ranges are a jump up again though, both the flexes and 'trowel' trowels.
Not got past MT for sticking it in though , got a Nela , but not the premium. Seemed too rigid, Maybe good with cement though.
The new black nela laying on trowel is less stiff than the originals, massive improvement
Between a normal marshalltown and the marshalltown duraflex. Nice bit of give in the blade.
Yeah go through them like wildfire mate. Best finish but one tap or loose screw there f**k*d. Try ox they take a bit more punishment. Try sanding with fine sandpaper or sharpening stone sometimes gets nicks out but needs wearing in afterwards before you can finish with it again. If you get a kink or bend just chuck it its f**k*d .
