Hey all,
I’m no plasterer but have had a go in the past on small walls and even a small ceiling. Since this corona lockdown, getting a plasterer in is a no go, I prepared myself before hand and got all the gear before the lockdown to keep myself busy finishing up a kitchen/diner extension.
The kitchen turns up Tuesday still! Iv already plastered some areas which turned out spot on if I’m honest, couple little knicks to fill out after, but overall flat and smooth. Next on the list is the main ceiling...being 35sqm at 5mx7m, with a 3mx1.5m skylight opening in the middle, there is no way I’m going to be able to do this is 1 hit, or even complete on same day, any serious suggestions on how to go about it with a novice like me in mind, who simply cannot get a plasterer in, or wait til the lockdown is over (whenever that may be). As long as I get the ceiling done before Tuesday, the kitchen can be stacked in the middle and I’m confident in finishing the walls, the biggest wall is 5m as the others have openings.
With the ceiling, can a dry joint be sorted out eventually? Even if it means sanding down and possibly easy filling? Or will it just crack? Or maybe start and stop so the joints don’t meet, with skrim beneath, and easyfil after?
Any suggestions or words of encouragement will be welcome
