Low suction plasterboard ceiling lime skim
Woods
I'm trying to lime skim a low suction plasterboard ceiling. There's a few problems I'm having:
1. scrim tape doesn't stick to the boards
2. low suction, difficult bond between plasterboard and lime plaster
3. due to low suction, difficult to flatten: plaster is easily dragged off the ceiling; it does help to wait a couple hours to let it pull in, but it also gets progressively more difficult to flatten because the plaster gets firm. Floating and scouring in possible to a degree but not too much or the plaster gets dragged off again
I think I need some kind of bonding agent, but I have no idea as to what. I do have time, so I can run multiple tests until a satisfactory method has been obtained.
Thanks for the help!
Don't use lime plaster on the ceiling boards, just use multi or board finish.
If the boards are old and dusty PVA them first let it dry then scrim the joints.
You could also staple the scrim on or plaster the joints then embed the scrim in like old school jute scrim.
NO LIME ON PLASTERBOARD.
There are some very advanced materials available in Belgium. Go to your builders merchant and purchase Gips red brand plaster or better still Tarmac self finishing plaster this plaster is pre mixed and sets on contact with air.
Betokontakt
You'll need to the prime the boards with first with a grit primer to get a mechanical key. I normally use Baumit Premium Primer, so as to maintain breathability, but you could also use Febond Blue grit, or similar, as well.
cheers
How necessary do you think this is? It's only two coats, 5mm in total, and I did some test patches and it adheres very well. The trick seems to be to just leave it alone after applying the first coat and give it a couple of hours to pull in before flattening and scouring, that way you don't pull it off. The other thing is to make the mix lime rich, like a 1:2 ratio.
The day after, the second coat (1-2mm) goes on without issue.
If you use a primer then it's guaranteed to stay adhered. If you don't then there is the potential for failure in the future. Adaptavate Smooth, a lime based finish plaster, can go straight onto plasterboard. But most other bagged limes that I have used recommend applying a grit based primer first. This is the recommendation of Mike Wye using their lime putty finish plaster.
What do you mean by "low suction plasterboard"? That plasterboard is low suction, or a specific type of plasterboard. Adaptavate smooth can't be adhered to all boards. They recommend grit primer for some plasterboard, maybe the moisture resistant variety?
whenever a background has high suction, I find that I get very a solid bond. On low suction backgrounds, you have to apply it and then don't touch it for hours. Only when it starts to stiffen up can you start to flatten it. The plasterboards I'm using are very low suction. If the lime plaster is lime rich then it forms a good bond on it if you don't overtrowel when applying. But if my lime plaster is a 1:3 ratio, then the bond is really shitty.
I do think you're right though; it's probably safer to use a bonding agent. We don't really know how time will affect the bond. In case of bathroom leaks or whatever... I'm certain that the lime plaster will come off if the boards get excessively wet from upstairs. So best not be skimpy and just prime them.
I've gotten betonkontact which was recommened here, but I bookmarked your recommendation and I'll give that a try on the next job. I like the fact that it has some environmental labels.
