Does anyone know a nicer product for cement board instead of parex maite. Tears like mad with a sponge and something that's a fast setter.
K rend HPX.Does anyone know a nicer product for cement board instead of parex maite. Tears like mad with a sponge and something that's a fast setter.
Which ones the best to sponge? Found lac tears a lot too unless you hit it right at the end?Every manufacturer does an equivalent like Webers is their Lac, K Rend HPX etc.
I found Maite the worst to use but I also stopped sponging, instead spat flat then next morning I use a rasp type trowel from pft North to get any lines out.
The really High Polymer renders for board will all tear. Just got to let them go a bit more.Which ones the best to sponge? Found lac tears a lot too unless you hit it right at the end?
