It does sound it doesn't it?That advice is dangerous as f**k.
good tip some times my dewalt mixer trips some houses not often but it does it from time to time/maybe wake up dead though@malc,View attachment 40783 electric tripping I was getting in a right panic couldn't sort it out ringing around no one had a sensible answer found this old thread, worked a treat![]()
It is because it could generally be a fault. Without the earth connected in the the plug the only way the fault can get to earth is through the person holding on to the machine. It can only take 50 milliamperes to kill an adult so if the machine is 2200 watts that’s nearly 9 Amps of current which is 9000 milliamperes. Only a fool would disconnect the earth and work with the machine.It does sound it doesn't it?
you wont last long tapiti think an earth cable is health and safety gone mad, cut them off if it means you get to work in the rain.
no but i will go out with a bang.you wont last long tapit
like a slice of crispy baconno but i will go out with a bang.
sausagelike a slice of crispy bacon
F*****g hot dog I would saysausage
EVENING GAV, YER SNAKE.Ffs, just get on with it !
Regularly get a shock of the ritmo and leads,It is because it could generally be a fault. Without the earth connected in the the plug the only way the fault can get to earth is through the person holding on to the machine. It can only take 50 milliamperes to kill an adult so if the machine is 2200 watts that’s nearly 9 Amps of current which is 9000 milliamperes. Only a fool would disconnect the earth and work with the machine.
240s just a little tingleThat advice is dangerous as f**k.
yes and its only 230 now so not even a tickle.240s just a little tingle
It actually comes out of the transformer at 255V. Nothing changed apart from the nominal voltage to earth written in the regs book due to fluctuation at peak times. Plus it’s not the voltage that gets you it’s the Amps.yes and its only 230 now so not even a tickle.
I eat amps for breakfastIt actually comes out of the transformer at 255V. Nothing changed apart from the nominal voltage to earth written in the regs book due to fluctuation at peak times. Plus it’s not the voltage that gets you it’s the Amps.
transformer?It actually comes out of the transformer at 255V. Nothing changed apart from the nominal voltage to earth written in the regs book due to fluctuation at peak times. Plus it’s not the voltage that gets you it’s the Amps.
Skin shed ! All shiny and good !EVENING GAV, YER SNAKE.
you speak with f**k*d tongue.Skin shed ! All shiny and good !
You insult me !!!!you speak with f**k*d tongue.
Ah, get it now!You insult me !!!!
no, you just take it as an insult, thats your buisness.You insult me !!!!
how you spell" business?"no, you just take it as an insult, thats your buisness.
Good question ? I vote for outside, makes the point more reverent.question mark inside or out of speech marks?
Wet the labs hands and ask him to hold the machine to stop vibration , he'll give you the nod if something's not quite rightThat advice is dangerous as f**k.
Depends where your mind and soul are facing .which way is up if the earth is spinning
