marmorit up210
richardbrown
Have a house to spray in up210 but the weather is looking a bit ropey .... does it pick up the same as s/c or quicker guys ???
if its quicker it might be worth risking it
cheers rich
doing my head in ..... cant get it to spray properly unless its real stiff then its a cont to rule off.
The bag says spray at 420 but we had to have it at 380 else it was wet dry wet dry even after changing to a new d-63!
Grrrrrrrrrrrrrrrrrrrr
when we do it we dont fill the hopper too much just one at a time so it stays loose it does help and rule the first coat with serrated edge
up210 is very coarse heavy stuff and if you rule first coat with serrated edge it holds up better then bed mesh and tighter coat over top
