Mesh beads
S a plastering
Hi when your doing one elevation at a time when applying the mesh corner beads do you apply the adhesive round on to the next elevation then bed your bead in or do you just fold the mesh back when doing your next elevation cheers
The adhesive must be under the bead for spec. Continuously Spread the whole corner past where the mesh falls and then pull the gear through with your trowel. Then give it a tight coat over the top. This way when you come past with your wall mesh it gets Coates again at the corner.
The whole bead and spine is suspended in the middle of the base just like the mesh.
Like gibbo says...... Ha
Haha. I inspect loadsa jobs where mesh beads have been stuck on with dabs at intervals like render beads !!!!!
It has become my new pet hate. Drives me nuts.
Jobsworth indeed. I will retain my help/info in future. And it will be ricardbrowns fault
