Lastlaff
I'm a huge c##t...my boss used to tell me soMe to
I got the lastlaff - 'get me a cuppa you c##t', that what he'd say...a little addition of my secret ingredient went in everytimeI'm a huge c##t...my boss used to tell me so
I like it for my little mixes, I can only recommend the festool really, only that the price is on par with the refina so if someone does big mixes the megamixer or collomix might be better suited as they well provenHow you getting on with your mixer @zolco?
It's in daily use most of the time, although it's having its clemoitus days at the minute.I meant the festool, are you using it daily for mixing skim and dab what's it's settings like etc? I recon I can get one for £200
I bough a bosch drill in 1998 or there abouts for 550 pounds I've gone through a few whisks but the drill is still going strong. brilliant drill very powerfulYou'll get a varied response on that one fella.
Some lads on here (like me) go cheap and cheerful and use as disposable
Others go for the expensive top end ones
As long as it's rated powerful enough to mix the gear your using day in day out then any will work
At the minute I'm on with an el cheapo from lidl that's been doing OK once I got used to the variable speed being on the trigger when I first used it there was more on me than in the bucket!!
My last one was a German make that lasted 6 years
The budget brands are generally vitrex
Or spend a lot and get a mega mixer
Or of your a tight are drag the ponch/wheel out![]()
