if you use less cement but more waterproofer on a damp job is it more likely to be less or more waterproof? ALL DEPENDS MATE, LABEL USUALLY STATE'S MIX RATIO
i would have thought the less cement you put in, the less waterproof it would be, seeing as the waterproofer reacts with the cement content? or doesnt it then?
what does actually happen if you put old mix back in the mixer? CONTAMINATES THE MIX AND MAKES IT WEAKER
now tell me why?
if you use a 4:1 scratch coat and a 3:1 float coat which one will fall off first? PROBABLY NETHER AS LONG AS YOU KEY IT PROPERLY... WAVY DEEP SCRATCHES
shouldnt it be the other way round though?
what happens if you use soft sand for a scratch coat and sharp sand for a float coat? NOT MUCH AS-LONG AS ITS WELL KEYED, SHARP SAND COMPACTS BETTER SO IT GIVES YOU A STRONGER MORE SOLID FINISH
again, wouldnt this make the float coat stronger than the scratch coat?
what happens if you put render on 30mm thick in one go? ALL SAND AND CEMENT SHRINKS WHEN IT DRIES OUT, WITH THINNER COATS THERE IS LESS CHANCE OF SHRINKAGE CRACKS
nice one,could you add some lime or replace some of the cement with lime to enable you to put it on thicker?
why do damp companies say you shouldnt paint a newly plastered wall with silk paint even though its had 'waterproofer' in it and its been allowed to dry for 3 weeks? PROBABLY JUST AN EXTRA PRECAUTION INCASE THER IS ANY MORE MOISTURE TO COME OUT OF THE WALL, ASS SILK PAINT IS WATERPROOF THE MOISTURE LEAVING THE WALL MIGHT CAUSE IT TO BUBBLE OFF, PERSONALLY I DONT LIKE TO SEE ANY FRESH PLASTER PAINTED WITH SILK AS IT SEEMS TO SIT LIKE A SKIN ON THE FINISH RATHER THAN SOAKING IN
that wall may take up to a year to dry out properly, no 'probably' about it.. incidentally, as long as you mist coat the wall properly before you apply any other paint, you will have a key, dont be putting neat silk paint on bare new plaster! and silk isnt waterproof, its water resistant...
whats the difference between retarder and waterproofer? RETARDER GOES IN THE MIX AND SLOWS THE SET DOWN, WATERPROOFER WONT SLOW IT DOWN BUT IF PUT IN THE SCRATCH COAT WILL SLOW DOWN THE SUCTION GIVING YOU MORE TIME TO WORK THE TOP COAT
if i put waterproofer in a mix, would it re***d the mix?
whats the difference between waterproofer from jewsons and waterproofer from say, sovereign chemicals or triton? NOT MUCH
apart from the fact that damp companiy specified waterproofer has a salt neutraliser/inhibitor in it...
what happens if you add frostproofer to a mix? IT WONT FREEZE, ITS LIKE ANTIFREEZE IN YOUR CAR
It'll also send your mix off bloody damn quick...
is it possible to skim render the same day? YEP BUT WHEN RENDER DRIES IT SLIGHTLY SHRINKS SO GOOD CHANCE SKIM WILL CRACK ALL OVER
so that would be a 'No' then?
does render still stay 'green' for a while even if you use orange sand? YES
Funny that eh? why not 'muddy brown' instead?
