D
Deleted member 32554
Guest
Any comment on mesh diffusing ghosting ?It’s more covering yourself mate , if a customer has a problem and you have not done your work to the right spec , you don’t have a leg to stand on .
Iv really only got it using sand and cement or ocr renders. Not on mono or tin coat system's. If the block work is very wet u will got it on mono. So just don't do it when its piss wet. I do new builds 7 Newton concrete block. All my jobs average about 300m2 a house. I can tell b4 I even start a house now just by looking at the joints. If they are dusty looking there is to mush Feb in the mix. I just say it to the builder or client. Iv even said to one builder I bet it was concentrated fab used hear. He said yes how do u know. I picked up a nail from the ground and scraped the mortar joint with it. Was like dust. We did the job did really get them. But 1 area under chimney on a wet day they are kind of visible. On that job. Over 20mm on that area.OK , only ever done lime/cement and don't intend to go back to it as I'm too old and having fun indoors anyway
Don't doubt modern is better but clemos comments on ghosting , over Feb block/ brick mortar got me curious , zombie won't answer me about the mesh comment and don't blame him blame tbf but what's your take on mesh diffusing the ghosting , feel free to take the p155 as long as you don't mind it back , been a good laugh lads , jess don't forget to ask permission
Especially baged renders they will crack for fun.Not really you can just look at sand and cement it will crack.
Cheers for the input , and everyone else, spend too much time looking for problems lolIv really only got it using sand and cement or ocr renders. Not on mono or tin coat system's. If the block work is very wet u will got it on mono. So just don't do it when its piss wet. I do new builds 7 Newton concrete block. All my jobs average about 300m2 a house. I can tell b4 I even start a house now just by looking at the joints. If they are dusty looking there is to mush Feb in the mix. I just say it to the builder or client. Iv even said to one builder I bet it was concentrated fab used hear. He said yes how do u know. I picked up a nail from the ground and scraped the mortar joint with it. Was like dust. We did the job did really get them. But 1 area under chimney on a wet day they are kind of visible. On that job. Over 20mm on that area.
Just one comment , the dusty mortar, ,, also caused by being over mixed , even correct Feb levels can produce the same effect you are talking about , microbubbles in excess result in biscuit , when set the mortar can absorb more water , so soaks up more rain and then weeps to produce ghost as render dries ??
Its like all new products , trying to simplify things , then people forget they have a brain lol , bit like grit and PVA, Friday mix on skim , chucking water on the wall, endless fun , I just smileEspecially baged renders they will crack for fun.
I wouldn’t have thought so , but doesn’t mean I’m right , lolAny comment on mesh diffusing ghosting ?
Last summer with that heat I did some gables with white roughcast that probably I really shouldn’t have as it was far too hot,anyway I managed it all applied properly to the correct spec and depths all 100% but now if the panel ever gets wet ghosting can be seen in the odd part,either to dry for to long or the heat has killed the strength of the gear!builder wanted it done I got paid and I don’t lose any sleep over it,s**t happens even with cast never mind modern rendersCheers for the input , and everyone else, spend too much time looking for problems lol
Had a builder that used to do a bit for , didn't get much as he can plaster ( reasonably ) and on the councils list for historic buildings , so he says , never get much cos he quite likes lime , middle of the summer , close to 80 ° expected ,west facing blocks probably 60 m2 , awkward scaffold ,Last summer with that heat I did some gables with white roughcast that probably I really shouldn’t have as it was far too hot,anyway I managed it all applied properly to the correct spec and depths all 100% but now if the panel ever gets wet ghosting can be seen in the odd part,either to dry for to long or the heat has killed the strength of the gear!builder wanted it done I got paid and I don’t lose any sleep over it,s**t happens even with cast never mind modern renders
You ever done that cork render? Supposed not to crack never heard of it till the other day.Especially baged renders they will crack for fun.
Was going to have a play with it. But didn't get round to it.You ever done that cork render? Supposed not to crack never heard of it till the other day.
Someone posted insulating render , not cork, a couple of months ago for free (supply only) as a promo , can't remember the post title , anyone ? , think it had poly beadsBe careful with the Cork Render, my opinion is it’s a bit of a passing fad. Not all it’s cracked up to be, no pun intended
Certainly won’t be the Cork Render suppliers whose name I won’t mention, they wouldn’t give anything away for free.
I actually had this conversation with a marketing guy they’d got. I asked why they were charging £200 per tub on a brand new product they were dying to push out there and why weren’t they knocking buckets out and flooding the market.
He compared the product to TESLA (electro cars worth about £60,000)
My reply was “and how many Tesla’s do you see driving about?”
Eco cork insulated render,I guy down my ways makes it.mike wyeYou ever done that cork render? Supposed not to crack never heard of it till the other day.
I’ve used mike wye. Decent stuffEco cork insulated render,I guy down my ways makes it.mike wye
What's the advantage of cork over poly ? Apart from eco principalI’ve used mike wye. Decent stuff
It was lime plaster. Not used the cork.What's the advantage of cork over poly ? Apart from eco principal
