When hand applying monocouche do you coat the whole panel with the first pass and then put thw second pass on or would you put a section on and then put the second pass straight on? Been getting a lot of air pockets in webber and the serrated edge isn't getting them. Im thinking its sagging because the first pass is too wet but then always worried if i let first pass harden i will get problems scratching back? Thanks in advance
