D
Deleted member 32554
Guest
Never needed to sugar soap , only to clean glossy/ non absorbent surfacesIs that why some spreads blue grit the walls in case of wallpaper paste or do people still sugar soap them
I use wickes and selco, I got this batch from selco thoughWhere do you get it from , I only buy from local Wickes , well stored and very high turnover , never a problem
Customers like to do as little as possible. Back in the day you could reccomend they sugar soap it.Is that why some spreads blue grit the walls in case of wallpaper paste or do people still sugar soap them
Only had it once , it was a bag still in date on a site one of the last bags, they kept their mf outside on a pallet overed with a tarp lolrang me up and told me the report came back as faulty. they test it
In a lab and also on wall. “Unworkable after 40 mins” if memory serves. I
Managed to finish it but was a ballache. You’d have stood no chance
Would you sugar soap a wall if wallpaper has been stripped in case there may be wallpaper paste still on the surface the only time I've sugar soaped was a kitchen ceiling that had grime and brown marks from all the smoking the customers did
It's not so much the use by date that's important it's if it's kept in open sheds exposed to moisture IMO makes all the differenceI use wickes and selco, I got this batch from selco though
Makes me laugh when they say it's all ready for youCustomers like to do as little as possible. Back in the day you could reccomend they sugar soap it.
Those little patches all over are ok aren't they lol
It's ok as long as they're good with a kettle lolthere's still bits of wallpaper on the skirting line and around radiator brackets coving adhesive still left proud they never fully do it properly lol
Welcome aboard , pay no attention to me and @Robbo123 , I'm making it up and he's a remainer , just vote Boris and it'll be allreeetHi Folks,
I've been a member for a while and enjoy the forum but never felt the need to post, until now. I have been using Multi for years and have never had a problem with it until the last year or so. It might be great gear to work with for months and out of the blue it's greasy and horrible to lay on and trowel up. I could not get to the bottom of it. What I have found lately in B&Q where I buy multi (nearest merchants and cheapest) is there is a mixture of pallets of the old orange bags and the new darker ones. For me the older bags have been the problematic ones so I decided I would mix a tub up with half and half old and new and it seems to be nicer gear and has worked so far, maybe worth a try or maybe it's a coincidence and the two bags are fine!!! Like some folk on here I never use water when trowelling except on angles and trowels. A definite NO NO for me is Skimming PVA when its wet/tacky. I Always let it dry for at least 5 hours but mostly overnight especially on big areas and then you can see if there are any problem areas the next morning before you start.
My book of feng shui lists many things that could have an adverse effect.And airflow
Multi has been up and down for ages now. The chewing gum shite is the worst and it gives you no indication at all that it’s going to happen till right at the end when you’re trying to trowel it up! Lately thank f**k I haven’t had that happen but it’s just been so greasy when you go to trowel at the end like it’s not completely setting? There’s no difference on any background.@Cockney1 can you explain the difference to schoolboy little issues like cold walls n wallpaper paste to actually using bad gear
I always tell my customers to sugar soap walls after stripping paper.Customers like to do as little as possible. Back in the day you could reccomend they sugar soap it.
sugar soap every time, painting, plastering, tiling.Is that why some spreads blue grit the walls in case of wallpaper paste or do people still sugar soap them
you don't need to bathe, but it helps to keep duvet clean.Never needed to sugar soap , only to clean glossy/ non absorbent surfaces
Number one on that list you.My book of feng shui lists many things that could have an adverse effect.
I'll keep that in mind, Cheers mateWelcome aboard , pay no attention to me and @Robbo123 , I'm making it up and he's a remainer , just vote Boris and it'll be allreeet
Confirmation is here@The Apprentice Gary, can you confirm to this bone head both lots (separate occasions) of gear of mine was sent for testing came back as faulty.
So you work for bg. And admit gears faultyConfirmation is here
Great , can you say what was wrong with it and was it a faulty batch or problems with after salesConfirmation is here
To think a product is not routinely tested is beyond me , have never had a problem with in date and correct storage , we aren't talking of your local home brew merchants this is " the " companySurely if Multi gets tested and comes back as faulty it would have to be removed from the shelves and we be told not to use it??
I got told they knew they were sending out faulty gear from one factory but couldn't figure out why it wasn't right. So they just kept on churning it out there anyway. No fucks givenSurely if Multi gets tested and comes back as faulty it would have to be removed from the shelves and we be told not to use it??
Silly question but can you use Board finish on re-Skims?Multi is awful sometimes, impossible to get a decent finish.. I would say once every couple of months you get the chewing gum shite.
I use board finish 90% of the time now, although it does suffer the same issues.. it's still more consistent and nicer to use.
YeahSilly question but can you use Board finish on re-Skims?
f**k pva. Pre grit is the way forward.
Do you use a weaker mix to first coat or just the one , any diversion to this procedure due to background , wall structure , and do to lay on tackyPregrit is a total waste of time in my opinion, very rarely needed.
I mix PVA/SBR/Water, roughly 1:1:1, goes way further than just PVA, a lot stronger, much better at controlling suction etc/
And to matey above.. yes Board finish on re skims.
Not used sbr on internals. May have seen @Vincey mention this and @Olican .Do you use a weaker mix to first coat or just the one , any diversion to this procedure due to background , wall structure , and do to lay on tacky
And will you vote Boris lol
