EugenesDIYDen
So I'm insulating the kitchen with 63mm overall, insulated plasterboard. Kingspan recommended using 18 fixings per board and this is how many I used for attaching the first board. However it seems OTT. Looking at what other people suggest online, I've seen anything ranging from 6 per board to 12.
So how many do you reckon? The fixings are 110 mm going into 9" cavities. Also when I hammer the heads just below the surface, does it matter if the paper tears? It's easy to get the central part of a head a few mm below the surface, but it dishes with the edges flush and trying to get these recessed is what causes the tears. Do I need to use tape over the heads? I'm not going to skim the board, just paint over, so tape could be hard to cover.
