i think they dont sell it down the merchants because no general site plasterer has needed it. bg do all the work for you giving you a product with a consistent setting time, you know how much you can throw on in one go and you get used to it. within reason obviosly. if the setting time was silly tight, like casting plaster you be throwing a metre on, laying it down, trowelling it up, another metre rolling on and on... hence the 1.5 hour setting time, extended by up to another hour by adding another freshly mixed coat should cover most instances....
were having this discussion because someone has encountered areas they cant handle with a standard plaster.
maybe bg should start manufacturing 2 types of multi, 1 with a 1.5 hour set and 1 with a 2 hour set....
the lutece stuff i was using in france does exactly that, theres the lutece 2000 L and the lutece C...
nisus will confirm, the L is a 2 hour set, the C is a 1.5 hour set...
f;cking about with the retarder ratio is asking for trouble unless you know what your doing, bg do all that for us...
its perfectly possible to purchase the retarder, you just have to know where to look, maybe the merchants should stock it? but can you imagine the compaints when some f'ckwit overdoes the dose and sits there all day waiting for a set to go off and it just doesnt? dont forget things like temperature affect the setting time too...
its a gamble to use, especially when your used to a particular set time, you never know exactly how much time youve got, ill bet its a complicated formula thats been worked out over a long period of time by the boffins at bg alongside people who do this job day in, day out for the last 20 years, NOT people who have been doing it 5 minutes and are still learning how to use a trowel....
if you try it, dont go mad cos there was one area i stuck loads in as a bit of an experiment and i swear to god i could have sponged it back to life the next day....
1 teaspoon of the trisodium to a bag of multi i reckon will give you an extra 1/2 hour to 45 minutes...
as for vinegar? ive never tried but id start with a similar amount, maybe a capful to a bag...
