MamaELK
We're living with a back to brick and lath hall, stairs and landing and have been advised by our current plasterer to dot and dab plasterboard and it will be fine! The will be no problems with cold bridging or breathability he said. It had blown and cracked lime plaster before amongst other things.
I'd appreciate a second opinion or two, now we are back to brick as I've hired this guy based on his confidence in doing the job and prior pictures but really am not sure if we should be doing a traditional s+c and skim, or whether we could maybe batten out and insulate the coldest external walls? Gap between stair string and brick is 25mm so a problem. Would probably need a new faux string building if batterned out.
Anyone with the skills? It's freezing here currently! We're in Hull.
