Y lol I'm pulsedFor my bedroom ceiling. Old lathe and lime plaster ceiling. Has to come down and be replaced. I need to replace it with a board which is as thin as possible. 9.5mm plasterboard is the thinnest I've used. Is there anything thinner available? Ideally 6mm or thinner...
You can get 6mm contour board, it’lol cost you though.For my bedroom ceiling. Old lathe and lime plaster ceiling. Has to come down and be replaced. I need to replace it with a board which is as thin as possible. 9.5mm plasterboard is the thinnest I've used. Is there anything thinner available? Ideally 6mm or thinner...
Just board between the joists.... It will look like you live in an old barn conversion . Win Win .For my bedroom ceiling. Old lathe and lime plaster ceiling. Has to come down and be replaced. I need to replace it with a board which is as thin as possible. 9.5mm plasterboard is the thinnest I've used. Is there anything thinner available? Ideally 6mm or thinner...
Theres 6mm contour board we use it on archesNo and Why ?
How do you fix the beads for your arches?Theres 6mm contour board we use it on arches
Spike em on with clouts the way I've been doing it for 30 yearsHow do you fix the beads for your arches?
Would that tape temporarily hold my wing mirror together! I may of found some use for it!!How do you fix the beads for your arches?
Spray glue, clouts, scrim then staplesHow do you fix the beads for your arches?
Tape is probably too advanced for a veteran.Spike em on with clouts the way I've been doing it for 30 years
Nah unfortunately not, first day back on the tools today!Nice pool you still away!![]()
Depressing aint it! Don’t you go giving yourself a hernia slip back into it slowly at your age!Nah unfortunately not, first day back on the tools today!![]()
Lol. I’m in my prime mate!Depressing aint it! Don’t you go giving yourself a hernia slip back into it slowly at your age!![]()
Have you ever used hard board to form an arch ?....Just askin.Spike em on with clouts the way I've been doing it for 30 years
I’d go with colour, something different
Looks creepy,imo.I’d go with colour, something different
