Hoddo
Just borrow the wifes....
I've worn all hers before, they're getting boring now
Sounds good to me, will try mine once there in..s*p*r*lex you can use it straight out the box but it gets better just like any trowel
Im well impressed with it
Trying to stay working and out of hospital for now,been lucky but on too strong a painkiller so who knows, I like to see how the young guys are making it easier and not wrecking themselvesYou should also try Airless its awesome on refurbs
When we two coat we always flatten first coat allow to pull in then top. Works fine.
As andy said these will not flatten large trowel lines that are left to long like a standard MT but if you lay on neat they are sweet
@JohnDoe I was using the 14in mate. I use an 11in most of the time but these trowels don't pull on the wrist/elbow like most so I felt fine using it.@essexandy ... What size trowel were you using mate?
Good review, concerned with laying down straight on top of first, I prefer the first to pull in a bit before I second, find it finishes better this way,perhaps my first is thicker than most as well.
Its a habit I need to change used to a thick first coat probably from many years of going over old wall set so need the waiting time for laying down@JohnDoe I was using the 14in mate. I use an 11in most of the time but these trowels don't pull on the wrist/elbow like most so I felt fine using it.
The walls were ready to lay in straight away @johniosaif. I don't put on thicker than need be, 2mm all in.
