Let me kno what's happens with these, think I'll invest in some of these after they've being tweaked.
Would that be the use of wing nuts instead of the alum key set up?? A couple of the lads suggested that on here and sounds a good plan?? For the record used my eze spat again today on ceilings and its criminal how it saves so much time and effort!! @SpankySouthport had to leave early and asked if I'd be OK managing the ceilings on my own?? I just laughed pointing at the eze spat, bloody doddle :RpS_thumbup:The only tweaks being made will be to the Pole at!tachment. The Spat itself wont change
18"" nela is **** the top of mine started coming away cos there ******* glued on!!! Trowels without rivets what a load of ****!!..
My 16" is the same, luckily not by much so still useable but can tell it's going to get worse
Does the warranty cover Mine getting bent in the van?
Tried straightening it out with no joy. If anyone wants it for cutting down or spare handle etc pm me and you can have it
Also we explained there was a problem in manufacture a while ago, which lead to someone at NELA losing there job. There was a few faulty ones which slipped through the net. Out of 4000 sold we have had less than 20 returned for this reason. This has all been rectified now, NELA are so confident in the quality and so are we that there is the 5 year warranty that we will honour. Also the 'Glue Tape' which holds the two blades together has been improved as well so there shouldn't be any problems.
Your determined your no getting on with these superflexs's lol on another note the new s*p*r*lex very rarely leaves the van as contrary to what others say it does need broken in and no one can be arsed doing it.
My Refina sf was bought from bed dy. don't think he'd done much with it and mine was fine to use straight away
Hi Gareth,
As you can imagine its very hard to pick everything up on here. Could you please give me a call on 01242 236699 and we will get it replaced for you straight away, sorry for any inconvenience
Ryan
I am one of the guys that say you can use it st8 out of the box Stuart. I bent an 18 inch i think it was the other week by dropping it like the spaz handed guy i am. Got another used it straight away with no problems. They are a trowel that once you change your timings a bit they become so easy to use. I do wonder if some people go on the first pass to early that i did at the start. I made more mess of what i had laid on. Once i got my head round a method to the way i plaster to incorporate the Nela sf I have not finished any skimming without mine since. I still could go back to the normal trowel but i can not see the point unless i had to. :RpS_thumbup:
its good iv been using mineI use the nela trowels every day, and have had no issues with anything coming loose... will be giving the PUTZ spat a try out tomorrow..
