Are they low suction then buddy ?Scud it first...bullit-proof key
Thanks rigsby... The wall is brand new, whilst it has no dpc it does have 4 courses of engineering bricks so don't think damp will be an issue... Thought about Ocr but im sure id seen on here lots of people had had issues with cracks ..4:1 is too strong it will probably craze. 5:1 scratch sharp sand. 5-6:1 second coat with 1 of the sand soft. Let the scratch fully cure.
Better still use a modern render like a base coat then ocr. Garden walls are usually built wrong for rendering and are problematic. I stopped doing them, not worth the comeback.
Its at my own house....lolOne coat big lash up don’t matter what the ratio is , rule it off once, don’t bother levelling it or filling in hollows and sponge it to death.
Get paid and block costumers number
Just looking at that myself... Cheaper than normal ocr also....Got a similar job for mates renter. Would the tarmac OCR be ok for this?
No problem, ive done years of internal on brick but little external and never on block..... Im thinking of using ocr, mesh the 1st coat and scratch it... Let it cure then top it with ocr.....Used a bag the other day on a porch ceiling. TBH, first time I've done any external render, but it mixed nice and went on well.
Anyway, sorry to hijack mate, but just interested in a reasonably failsafe method too.
Thanks pal, no need to rend aid or mesh then ?At this time of year you will be struggling with setting times, sliding and sagging.
I would do two coats in either s&c or ocr letting the scratch coat cure fully and the second coat being 6mm with Wickes hardener added. It will rub up full of water though so different to summer conditions.
Myself I would use Parex Parmurex being waterproof and put on late as and ibar it back to flat next morning. No annoying sagging and a drier surface sponge finish.
Stop bead under the copings and beaded edges so you can bar or rule off too and it will be flat
