new cornice
S a plastering
hi just some advice got 8x3m lengths of new cornice to fit had it run up its the same stuffthats in my cornice repairs thread the job has changed weve took it all down to replace it all
just wanted to know do you lads prefer to scribe the internals or mitre these angles are out a bit not perfect 90deg if scribing do you use a coping saw like the small gyproc coving or something else by the way its not a big profile as per pic in other thread cheers
You won't be able to scribe it.
45 it or as close to the angle as possible.
Fit up. Then fill the gaps with casting and carve as it sets. I did a post on fitting cornice a while back. Will dig it out.
