What do you use to stick the end of the board up with ?That's great Danny but still no button for getting people to take my " board joints mid joist " idea seriously
I'm sure theirs better but I used sfix general purpose silicon , nice and warm , only on my own buildings and a few friends , haven't had any long term problems with sag or crackingWhat do you use to stick the end of the board up with ?
Not necessary when i can experiment on my own ,wouldn't be nice to get a call back to a customer , the cost to replace / repair and redecorateObviously you do this only on overboarding . Is this to prevent cracks ? Why haven’t you done this on any paid jobs ?
Yes its to prevent cracking caused by joist movementObviously you do this only on overboarding . Is this to prevent cracks ? Why haven’t you done this on any paid jobs ?
Ok thanks was just curious.Yes its to prevent cracking caused by joist movement
f**k does that lot mean
I agreeDanny f**k off the T***s on here might help! You have a handful of people that help post , the rest make the forum and you look silly
The other advantage is eliminating trying to get a good fix to un square , incorrect pitched and bowed joists,Ok thanks was just curious.
I suppose you Save time on cuts and waste . I’d give it a go but like you say don’t want to be going back to any jobs if it sags . I’ve stuck boards to walls and lintels with no nails and silicone. Been ok but never ceilings . I can see one disadvantage though you wouldn’t be able to skim it same dayThe other advantage is eliminating trying to get a good fix to un square , incorrect pitched and bowed joists,
All boards are cut approximately to length , all dead square and no dodgy screws on the ends
That's a valid point , although I did leave props up for longer but after 20 mins you couldn't separate the boards , with the section joined being almost fully double boarded their is little sag force/ m2I suppose you Save time on cuts and waste . I’d give it a go but like you say don’t want to be going back to any jobs if it sags . I’ve stuck boards to walls and lintels with no nails and silicone. Been ok but never ceilings . I can see one disadvantage though you wouldn’t be able to skim it same day
I like sticks like s**t turbo, go through loads of the stuff. 15 min and it's a go. Use it on all types of jobs. Even use it for beads somtimes.That's a valid point , although I did leave props up for longer but after 20 mins you couldn't separate the boards , with the section joined being almost fully double boarded their is little sag force/ m2
So a lunch break or perhaps some other prep, not usually an issue
c**t.@Andy g thoughts on the rest api algorithm? Personally, I’m not convinced.
andy g where is he RIPc**t.
Thought you might be missing the Andy g intellectual debate.
I haven't heard anything either. But I did see this photo floating around the forum earlier.
Wonder if hes got lab to go get one bag of miracle grow. While the voices in his head keep him company.
