Theoldeduke
The grey celcon ones, whats the crack with sand and cement render on these. All internal. I know the mix will be weaker but what bonding sdhesive should/can be used.
Sand cement lime mix I would use is 6/1/1. Fibres in the mix also, sbr the block work the day before, 3/1 sbr water.
We have done lots of it, not so much now, but as we do mainly refurbs we are inclined for this mix where new meets oldi do not like sand, cement and lime floating, you end up with high suction and srinkage.
How long would you leave it before skimming normally?we have also used it sand cement and lime floating loads of times, we purchased the lime already mixed with the sand direct from the pit, we just added the cement. you had to time when to turn back and set to late and the suction would be high.
do you not use waterproofer malc?
You don't use lime with it mate it acts as a plasterciser
Yes, the 5 day wait to skim (cure) is difficult .all depends on the blockwork or backing. you get opposite suctions when you set, ie low suction block on floating high suction on set. and high suction on floating low suction on set.
on average you would not want to leave sand, cement and lime more then a couple of days. which we know is not long enough for the floating coat to srink back. that is why it has been supersede with hardwall.
