Evening all, another DIY project on the go, after some advice on which way to go with this. Property has a cavity wall (uninsulated), that has filled with mortar, dust and roofing debris over the years which has caused major damp to the inner walls through the bridging effect.
The previous owners have had a DPC injected and rerendered at some point, this held back the damp for a while but i,ve now knocked off all the effected areas and spend days removing bricks below the floor level to clear the cavitys of all the damp muck.
Now ready to render the walls , but not sure of the best way to keep them dry, i've looked at the plastic tanking products but they are very expensive! Another alternative seems to be tanking slurry, or just plain sand & cement with waterproofer added, what in your opinion would be best to use and in what order? Cheers in advance Pete
