ggb plasterers
Thinking of buying one any thoughts please
I wouldn't buy anything with that much milage, what goes on them normally
If u give me the money for a vw ill buy oneA VW will do that mileage 2-3 times over
My custom is big enough for 8x4 and the 1220x 2440 mdf boards which I use.
Also got a slot under passenger seat for 3m beads.
Lovely van so far, if the gear box goes on this its def me!
If you get either of those, or the Primastar get an 09 plate or newer. They changed the engine and gearbox in 09 and the ones after that are as reliable as any of the other manufacturers with the added bonus that they don't dissolve under you.What about the vivaro or traffic
How muchYeah I've seen a 12 plate that looks good with 55.000 on the clock
Gearbox my mechanis told me
I live on an island that is tiny and people are worried that vans with 70 /100 thousand miles from the UK are bollockes
I think an engine running hot is better than stop start with 40000??
Hope he had a good time here!Just realised the relevance of your screen name, my son was working in jersey for about 10 months last year doing geotechnical work on some old quarry ready for the developers to build new apartment blocks.
As far as the milage on any vehicle is concerned I have long since held the opinion that the more that is paid for a vehicle when it is new the more likely it is to be serviced properly i.e. if you can afford a 50k car you can afford main dealer servicing, if all you can afford is a 6k car then the likelyhood of main dealer servicing is less likely.
A BMW will f'up just the same as a Ford if it is not serviced
I just bought one 2weeks ago with 114000 miles on the clock and it's a great van for me I have been told that the gearboxes can be an issue but my mechanic told me if the van is looked after and serviced regular it will be good for 250 to 300 thousand miles as he has had 2 of them that he got that out of.
Just don't hammer the gearbox
Change gear slowly.
Also even though the badge says nissan they are all made with renault parts which includes the vauxhall vivaro
They were made by all 3 as a collaboration between them
The only real difference is nissan primastar has most of the electrical bits as standard not as an extra eg heated mirrors air conditioning and so on
Good luck with whatever you choose
it will be under warranty mind.I've got a 64 plate transit custom, have done 5k miles and the gear box has started playing up! Nearly need both hands to change down to second!
theres an element of truth in that.Just realised the relevance of your screen name, my son was working in jersey for about 10 months last year doing geotechnical work on some old quarry ready for the developers to build new apartment blocks.
