OCR over SS EML
FreeD
Phoned weber technical the other day, they advised me not to use OCR over EML. Apparently because the eml can cause cracking, expansion/contraction of the metal or something.
Any1 heard this before seemed like a load of b*ll*cks to me and them pushing me to use rend aid instead.
its because ocr is a one coat render over eml it should be three coats it will crack with just one so not bowlocks really just common sense
if i remember correctly ocr is banned in california as it was found to be cancer genic
most pre blended/mixed renders contain silica its usually ok but the fine dust can get in always be extra careful when grinding or sanding back/cutting into render especially with textured bucket coat.
yes silica is carcinogenic
its all in your coshh in the RA/MS
I'll suggest to the surveyor we go for rend aid. Malc wear a mask.
it is a bit late for me to wear a mask as i already have c.o.p.d [blocked airways[ through years of plastering, breathing in dust to fine for the nasel hairs
Smoker?
I try to wear full face respirator when doing internal work and always mix up outside.
Mind you i still get loads of s**t in my lungs just try to limit it.
I had an improver on with me about a month ago who smoked 20 a day and refused to wear a mask hacking off etc. No longer working with me. F**king idiot.
Smoker?
no i am not a smoker, but i do wear glasses which i find awkward with a mask
