Do you have it a little prouder than the beads when you spat like mono if you're going to I bar it pal?on ocr i bar to get flattter than flat or flatish depending on the mood but when there is still some life in it and then rub it up or just leave the fine texture for them - some peole like it. on mono i bar in the rubbing back process.
I used to float ocr with a polyfloat and sponge to be finished with either paint or texture but Stumonkey told me on here he was I sectioning and then i tried it never polyfloated since except for on very small stuff when I want to get off, if you want it smooth just get a wet spongefloat over it after you I bar
OCR in winter is best rendered late in the day then I section next morning then rub up. Mega flat and smooth if you want it smooth.
will try this I section during summer and see if it works. Southern Monkey Render (Stu) does it so should be ok.
Just sprayed a barn in Pickering , first pass with mesh bedded in second pass flattened in with trowel and spatular. Rubbed up with sponge float . Looks mint
Seen that dot & dab geezer do it on his you tube vids. Think he used to be on here..... Oasis maybe? Looks a good way to do it
Did a krend job today. Small wall 2.8 x 5. I did hp12 scratch coat day before and went over it today with colour. Bearing in mind it was real hot today and the wall was in the sunlight all day. I I sectioned it then hit it with serrated float to finish. Half way down the wall I could see a join mark in the finished wall. Must have been between mixes as one took a little while to be brought up. Pissed off massively! scrapped it off and am gonna do again on monday, never had this with krend before, can only put it fown to the hot weather. Anyone else had this happen? If do what can prevent it? ?
Glad to see you can read and digest writtenNo staff or float mickeyboy?
