One coat over brick.
Dr.B
I have a customer who would like the brick plinths on his house rendered over.
I am intending to paint red-grit over the brick and would like to apply a bagged colour render over.
Can anyone suggest a suitable product that can finish similar to sand and cement.
Sent from my E5823 using Tapatalk
Sand and cement and lime ha ha
nd
What do you mean red grit?
I can only picture Everbuild Redergrip?
If it is just render then Rendergrip if you can't get Microgobetis then Parmurex or any other ocr.
As said above below dpc it will get dirty.
f**k off the bagged render idea
Just prime with say micro of r10 then render in sand & cement
Get the dollar and move on
You wont need sbr if using micro. But you could sbr prime the wall then add sbr to your ocr. That will stick as a base. A bugger to rub up though. It sticks to your float.
It will get dirty whatever I use with splash from concrete path.
I want bagged render so I can do in one coat and have a light colour without too much hastle and I don't have a lot of room on the job for mixing.
When I say red-grit I mean rendergrip yes.
