Squarehead
What do you mean? PVA the join and just stick it up when tacky?Yes you can pug i have even had the lab put it up with pva at contractors request
I know someone who tried that and was an epic fail!!I might try masking tape
YesWhat do you mean? PVA the join and just stick it up when tacky?
I've used quite a bit wet and stick paper tape over the last few years but the only problem with it is you have to put it all on the day before.
Ta. Gonna try that. Couple of staples if need be too. This is what's good about this forum.
Belmores sell it.Where can I buy it.
You can also get it from the drywall emporium on-lineWhere can I buy it.
Belmores sell it.
Are you using cls or treated gear for studding as that could be your answer, cls 99% kept dry indoors and covered, treated might look dry it's still carries lots of moisture. Wet studs can pull the boards about and cause cracksThanks for everybody's views, cracking is probably more something I have to deal with as a builder than a plasterer will have to, as when they appear when we are decorating I have to pay the decorator to keep filling them but this wet n stick looks like the same results if not better than paper tape. The main areas we have problems are any plasterboard attached to new wood and large areas. The project we are doing at the moment has a roof space as one area in excess of 100m 2 and this has been paper taped but we have still got some cracks mostly at the apex but interestingly enough not where joints in the plasterboard are so it must be to do with expansion and contraction of the plasterboard and plaster.
Where can i get a mushroom fixing machine gun?Paper tape is 7 times stronger than scrim. Most of the time I'll tape up the joints inbetween sets of skimming. I don't do the corners as it's to slow
Paper tape is by far superior to Scrim anywhere that’s vulnerable to cracking I’ll use it and I never have a problemHi wondering if anyone could back up my thoughts on paper tape which are that as a builder I ask my plasterers to use paper tape prior to skimming on any areas vulnerable to cracking ie. large ceilings, solid wall to stud wall joints as I have the come back to put crack right and I have rarely seen a crack come through paper tape but I constantly get told by plasterers that it is a waste of time but British gypsum recommend paper tape for a stronger joint so would be interested to hear other plasterers views for and againnst.
