Parex Monoblanco BL10 stain
Weeled
Hi,
has anyone had a stain on the Parex monoblanco render that professional render cleaner will not remove?
we are foster Carer’s and the child we have has made some enemies that have very annoyingly threw some eggs at the house at midnight, we discovered it at 6am so the egg has stained.
has anyone managed to touch up with paint before and could recommend a paint?
it would be hugely appreciated
  • Parex Monoblanco BL10 stain
Hi,
I've no idea about removing the stain, but painting the affected area will stand out worse than the stain.
Probably not enough over hang of the window sill, it looks really tight recommended normally 40mm I’d try Monty’s miracle cleaner on it first if that didn’t work then you could paint it
Hi,
A doff specialist render cleaning machine will remove that,just look for someone in your area that has one
