M Mikej1982 New Member Mar 31, 2020 #1 Hi guys do i need to grind off tar from foudation. our can i just wall bond it good then spread one coat then float finish
raggles Private Member Mar 31, 2020 #3 Heat it up with a blow torch and then blind it with sharp sand for a key. Anything you put on top of it will take forever and a day to dry out though.
M Mikej1982 New Member Mar 31, 2020 #5 smoother09 said: Pics tar Click to expand... The tar goes down 1.5 feet under that membrane Attachments 20200323_111029.jpg 1.9 MB · Views: 296
martinemj Well-Known Member Mar 31, 2020 #6 I'm bit unclear what your going to do.... Are you rendering the bottom ....over the membrane
M Mikej1982 New Member Mar 31, 2020 #7 The membrane will be cut down. So its 3 feet wide. 1.5 of tar under membrane. Yes i will be rendering it
