Patch concrete ceiling
Topandtail
Hi, a chunk of concrete has fallen off my Mums outhouse porch ceiling. The hole is about 40mm at the deepest point.
How do I go about preparing this for render?
Do I need to put something on the rusty rebar and will a bonding agent be required?
Also can I build up render in successive coats to that thickness or will it just come crashing down at a later date?
Thanks,
Peter
Welcome.... that looks like it is getting very wet....
Where abouts in the old are you?
Sent from my SM-G900F using Tapatalk
I'm in Newcastle. The house was built in the 1930s and I think over the years the rainwater has made its way through the concrete causing the rebar to rust.
There's a product I used years back called bellzona (I think) like a lightweight putty. Stuck like shite to a blanket.
