Link Removed
We used to do a lot of pebbledashing, very rarely do we get asked anymore apart from matching up to existing
As others have said, waterproofer in the scratch to kill suction and let your top coat or butter coat mix for as long as possible.
We generally add a shovel of hydrated lime to the top coat to aid plasticity and brighten up the finish,
Some people use a bucket, others pick up and clean all the droppings off a sheet.
We use an aluminium tray and paddle.
Work in bands of about a metre and if there is suction when joining up, splash the surface with a little water.
You should test the suction of the scratch coat first, splash a little water on it and it should remain on the surface for a few minutes, if not, soak the wall first..
