Bit confused as the literature shows airless gun with a roller etc, and I just got a swing m offered for 2.5k so thought it might work, but had the gut feeling that it's only a conveyerI'm sure it's just a conveying pump zol it's the swing airless L you might need to look at unless there is a kit for the M to convert it im sure one of the Pft guys will point you in the right direction, I've been looking at the swim M myself the last few weeks they seem like a good bit of kit but like you said there limited info on the swings
Cheers mate, I thought so, I have no luck thenM&L are just conveying pumps with different output. PFT swing airles is the one you are after or PFT samba XL, the equivalent of graco
This is the one, I'm in Germany till tuesday can collect it for you if needed https://m.ebay-kleinanzeigen.de/s-anzeige/pft-putzmaschine-swing-m/799697945-84-341What kit does it come with for £2.5k I'd be interested in having a look at it
You should have said the 6k m2 are in Germany. I could have helped.This is the one, I'm in Germany till tuesday can collect it for you if needed https://m.ebay-kleinanzeigen.de/s-anzeige/pft-putzmaschine-swing-m/799697945-84-341
It's done now mate sorryYou should have said the 6k m2 are in Germany. I could have helped.
