Pft swing m
zolco
Does anyone know if the pft swing M is capable of spraying airless plaster or is it just a conveying pump, limited literature online about it.
Zol
I'm sure it's just a conveying pump zol it's the swing airless L you might need to look at unless there is a kit for the M to convert it im sure one of the Pft guys will point you in the right direction, I've been looking at the swim M myself the last few weeks they seem like a good bit of kit but like you said there limited info on the swings
M&L are just conveying pumps with different output. PFT swing airles is the one you are after or PFT samba XL, the equivalent of graco
Bit confused as the literature shows airless gun with a roller etc, and I just got a swing m offered for 2.5k so thought it might work, but had the gut feeling that it's only a conveyer
What kit does it come with for £2.5k I'd be interested in having a look at it
The swing m is a conveying pump. It would pump and spray airless plaster but not at the controlled conditions or high pressure the swing airless will. You will also need a compressor to blow it on the wall.
I would use the 13mm pipe and powercoat gun to apply the material if i was using the swing M .
