Arti
Got some plans emailed to me today and ive only priced off plans a couple of times. Anyway it states for the walls 30mm Insulated boards screw fixed and skimmed. So i looked at the room plans and the arent studded out so i was abit miffed why it says screw fixed..................or does it mean dabbed then mechanically fixed??
Been trying to ring the builder for clarification but he's not answering...........Just wanted to ask the lads who price of plans all the time if im reading it right or am i just a doofus...............:rolleyes)
All plaster to be applied in accordance with B.S. Code of Practice C.P. 211:1966.
All plaster used shall be brought to site in unopened bags.
All water used to mix plaster shall be clean and free from impurities.
The skim coat to be 5mm thick applied to two coats and is to be the B.S. 1191 Part 1 Class B.
All finished plasterwork shall be smooth and free from trowel marks, spots, etc.
Prevent excessively rapid or localised drying out.
All external angles to be reinforced using Expament thin coat angle head.
Solid Walls (New)
Plaster new solid walls with 30mm insulated plasterboard screw fixed and skim 5mm
SCHEDULE OF WORKS
1. Plasterwork to newly built blockwork walls to be in 30mm insulated plasterboard screw fixed and skim 5mm
2 Supply and fix 9.5mm plasterboard and 5mm skim to new stud partitions and internal blockwork.
3. Supply and fix 12.7mm duplex plasterboard and 5mm skim to new ceilings (10kg/m3).
4. Supply and fix to sloped or T fall ceilings 40mm plusboard screw fixed and skim finish laid between and over ceiling joists
5. Supply and lay 75mm self levelling screed 80kg/m2 on 0.2mmwaterproof membrane on 75mm Kingspan TF 75 Thermaflor 0.2mmwaterproof membrane on beam and block floor linked to dpc
Solid Walls (New)
SCHEDULE OF WORKS
