Plaster on tiles?
  • Thread starter Thread starter Sara_Spread
  • Start date Start date
ok we're going off subject here. sara doesnt need to see the fact that bruce has no taste in fashion. we all know i'm the best dressed one here. phil when im on holiday in june im now going to wear my crocs and white socks. and the best damn tee you've ever had the pleasure of feasting your eyes on
steve cov said:
has anyone actually skimmed onto tiles using bond it? without bonding first.
Yes Steve I,ve skimmed over tiles a few times, I,m a big fan of Knauf betakontakt which comes in 20kg tubs for £50, I use it on artex, tiles or any other "iffy" surfaces.
This is exactly the same product as wickes bonding agent which costs about £13 for a 3kg tub.
I only ever use bonding coat to level out when theres any deviation greater than 4-5mm and use board finish cos multi hangs around for ages, I let the first coat really pull in cos you can see all the grout lines after first coat, second coat then goes on using only slightly less mix than used on first coat.
I trowel second coat up with as little water as possible because too much leaves you with bleedin blisters which can take ages before they will trowel out. ;)
Answer to question is what Chriss has said it is the only way to go dont use PVA IN THIS SITUATION
Bruce Willis said:
I was in wickes today and looked for their bondin agent, couldnt see it. ???
Yeah the one by me doesn't stock it either, but there is another wickes that stocks it not too far away,
this is a much bigger store though.
Where can you buy that knauf betakontakt stuff then i've never seen it?
Sara_Spread said:
flynnyman said:
What area are you from?
Staffordshire
sure there are lads on here from there you can also use gypsum bond it. Travis Perkins
36 Corporation Street, Town Centre, Stafford, ST16 3LY 01785259421
give them a bell but in my opinion travis are robbing bastards. :)
flynnyman said:
Sara_Spread said:
Staffordshire
Yes you can get Betakontakt from Travis Perkins but there tossrs for not having prices on anything, I play them and tell them I was quoted less over the phone, I paid £53 for the last 20 kg tub and I bet I could pay less if I try it on next time
give them a bell but in my opinion travis are robbing (french person)s. :)
