andrewbuckley
They didn't initially, they had to remove all opposite boards prior to us doing the work, another one of the many issues.
Hi mate not been on for a while, to busy not read the whole thread but if the fixers have not reversed the studs from the starter against the wall it will kink the boards.Hi guys,
apologies if this topic has already been posted. I and 3 of my lads have recently skimmed 600sqm of plasterboard walls on a site in Glasgow. A week after i finished I was called back. 70-80% of the walls have all peaked on the joints. All framing is metal stud, there are little to no peaks at the top or bottom of the joints, from 500mm onwards from top to bottom getting worse in the centre, has anyone ever seen this ?
Hi chaps, meeting went well. On the walk around the client he pulled a perticular wall, the said wall shook upto 100mm when pressed on with my hand. Knauf have done a report on the construction of all the metal framing and have pulled it to bits due to a number of reasons, 1 due to no bracing straps at the tops of the 3m boards (frame goes to slab height of roughly 4.5m) list goes on. I also got a straight edge on all joints and highlighted that all effected joints bow in the middle, all this was done in front of the company who I am subbying to's site supervisor. Client agreed with what I was saying, site supervisor pulled me up after the meeting saying I didn't need to highlight all those issues which I understand from they're perspective but when someone's pulling my work I want them to know why it is like that. Was I in the wrong ??
Anyways it is now down to another meeting between me the contracts manager and the fixers to decide who pays for me to rectify the work. I reskimmed a few more walls today, whilst the issues are becoming less noticeable the problem of bowed joists still exists. It's cost me £800 to rectify 50%, I've done this out of good will in order to keep customer happy as they throw work my way. I'm not in a position to do the other 50% for free so it's going to be a fun meeting.
I will ill have to be excused for not assessing the walls thoroughly, new to the management side of the trade, valuable lesson learnt.
Thanks for for the support guys
I fill my joints and beads but go straight over them why they tryin to bullshit you?
For instance first stud is fixed to existing wall flat bit against wall open end facing out so if you are going to start boarding from this corner the following studs go open end facing existing wallHi mate, what do you mean by reversed the suds from the starter ?
Hi guys,
