80 m2 large format internal porcelain .
1200x600 usimg- a level clip system - /50m on ground - floor @ rest in bathroom-This should be fun ....
Pics to follow.
View attachment 74735View attachment 74735
@Aliexpress diamond pads to finish porcelain cut edge View attachment 75039
ULTRALITE S1
Low dust, one-component, flexible lightweight S1 wall and floor tile adhesive. Non-slip with extended open time. Suitable for ceramic, porcelain and natural stone tiles and mosaics. Especially suitable for fixing thin porcelain tiles. For screed/render and plywood substrates. (Contains › 30%…www.mapei.com
Trust me, it's brilliant to work with, compared to other's, it's lightweight, flexible, you can pull a tile up or move it hours later,
just try a bag then thank me.
tile levelling systems ..
Love them or hate them ,they really is no other for large format …However I have stopped using these as intended .
As It does/can push the joint out .
What i do : is use the 1mm levelling clips & wedges @ with the tried & tested 2mm cross spacer to keep joints in check , I find it the perfect solution
Wakey wakey
No wonder with your wallstile levelling systems ..
Wakey wakey
