Have you had any problems with the knauf shelling of the wall when the skirting boards are fitted? We used to use in on barrets years ago was nice to use and yes get more on but as soon as any one did anything on the wall it just fell off!!
plastering/rendering machines,electric or diesel require a level of skill at the end of the hose.there are single mixers or duo-mixers in electric,some renders need the twin mixing before they enter the delivery hoses.remember you can also do liquid floor screeds,grouting or fire protection spraying with the same machine if you buy the right one.it gives you more options if plastering is quiet.there are quiet a good selection of used machines if you do not want to invest in a new one.
My only reservations is it being 240v. We all know what we're up against when it comes to site agents!
iv never had a problem. i changed my blue 240 plug for a red 3 phase and wired in a single live, and for some reason now they think its double the power and its ok. makes sense doesnt it
No shelling off so far..........fingers crossed!
Use an in line RCD.If someone did have an accident with the power supply to your machine you'd be proper fuucked though wouldn't you even if it was entirely their fault (say a shovel through your cable)? Not just because you were using 240v but because you'd tried to disguise the fact.
Use an in line RCD.
Got to say it does sound handy being able to plug into site supply. With no messing around with gennys. Does it ever cause any problems when others are plugged in or the lights start dimming etc? Is there enough juice on tap to turn the motor on startup etc?
Most site boxes are them big 10kva ones with 4 16amp sockets and 2 32amp sockets. I think the tranny is split up in to 4 parts, well it has 4 trip switches labled 1-4.
the first 2 are the 4 16amp sockets which is what everyone else plugs in to. The other 2 are the 2 larger 32 amp sockets which we find are never in use as no one is running 32 amp stuff.
So we have 2 leads with 32 amp plugs on the end. One goes to the ritmo and the other goes to a splitter that runs the water pump and the compressor.
We have no problems like this.
However when we first tried we just used the supplied leads with smaller 16amp sockets and where eveyone else was also plugged in on them 2 circuits it kept tripping the trips.
So i looked at the box and thought hang on only half of it is being used, hence we made the leads up. Also our genny has 1 16a and one 32amp socket so it makes sense to make a lead up for that.
When skimming we where using £25+ a day on fuel and that was using it sparingly. I reckon £30 plus for fuel a day if that your only power method, plus the ball ache of having a genny on site for indoor work. Ours is in the van incase the site power goes.
On private jobs we have a 5 kva tranny which plugs straight in to a 240v lead.
I thought you were only gettin 2 sprays a day.We are switching it off when not in use. I did think wtf aswell!
people like to hate, i'm not one of them, i'm grateful i got to have a look!
No it's people trying to be honest and as yet aren't convinced and I don't think mr curriers rant of how fast amazing he is helped .......25 quid a day in fuel **** that loser
