Flipping hell. I'm Getting £5m2
Where you been you lush?I have been away on hols, but the last job i did all the bottom of arms were sore, i`, sure it was the multi i was using, i`m never one to complain about the quality, or the bags, but id swear blind that stuff almost burnt my arms
Bg recomend 2mm on board now I think at one point it was 5mm?one of the old timers may correct me on that though.Going back to years ago ime sure we put it on thicker because of the Jute
No harm meant by it lol just a little before my time jute scrim.:RpS_thumbup:Ahem... excuse me i am an old timer.
@zombie watch this space mate we are organising something you will be interested inI will find out from BG if I can say anything yet
I doubt you will get an answer from BG based on what I have read. They don't need to answer your queries as you will buy it anyway so don't need to know. Now if you had an alternative you would be able perhaps to leverage them a bit. That said there could be all sorts of things that will change how the material performs. The key I guess is consistence. The products seem not to be behaving consistently so you can't predict or adapt to fit. This could be a change in gypsum raw material source, material grading, blane test results, particle size, shape and solubility, different plasticisers, longer or shorter plant storage times, and many many more. It must be frustrating not getting the answer you want but if you think about where they are if they tell you there is a change you and your colleagues could open the flood gate of claims against them. I think you are onto a loser trying to get answers.
Why cant bg make a finish like knauf ??
I thought they had a 60 or 90 minute bonding coming out?I would much rather have faster setting plasters say 30 mins skim and bonding so as to get on with private jobs etc. Added fibres too would be nice in multi.
The mine is at a fairly constant depth gypsum sits in a seam about 8ft thick approx 100m below the surface,
From what I understand the mine at east leake has enough gypsum left for about another 20years before the whole mining operation moves to a new site (Yorkshire I think).
The mine are required to send material to the surface with a minimum percentage of gypsum in.
They obviously use the highest quality gypsum for dental, casting and even for the brewery's as most ale has gypsum in.
This leaves a lower quality gypsum for the rest of the range obviously there is a tolerance for the quality of the gypsum used in finish, I suspect the closer they get to the lowest acceptable level the tolerance allows, the worse the finish becomes just used a pallet of multi that was almost like clay sticky, greasy then it flash set, pallet before was a dream to use.
Everything was constant background, the application, number of trowels the water came from the same tap, temperature was the same, boards came off the same wagon and went straight in the plot's.
The only thing that was inconsistent was the multi (the bag dates were the same) the plant batch multi in quite small amounts about 4 tonne at a time so your not guaranteed that the top of the pallet will be the same as the bottom as they may came from different batches.
Irish gypsum is all ready making short set skim and bonding.
Link Removed
Only ever seem to have consistency issues when our gear comes from Sheffield insulation.
Gears come from ccf this week and its been a joy to use.
Must just be a strange coincidence
Storage by suppliers is a lame excuse, the lorries from bg delivering to suppliers are not temperature or humidity controlled!
